Now, not to be confused with an ECU that holds fuel mapping-a CDI is the modern version of a distributor. Carb models only.
Afaik it takes a signal from 4 coils in the crank position sensor, which tells it which ignition coil to send voltage to.
Repairing a blown cdi is not rocket science, but without being able to test it and troubleshoot the fault it can be a nightmare.
A recent delve into the world of getting them overhauled got us quotes of 2-300 euro from places in the uk and holland. And shipping and waiting times on top of that. The resisters, capacitors, diodes and transisters that need to be replaced in most cases can be had from maplins/radionics for about 80euro all-in. If you can solder, you can fix it.
What Im trying to determine is, how to test one reliably without an oscilloscope. Im starting from the possibly basic assumption that all we need to do is input a Dc voltage on one pin, and look for an output on another.
Now, what im trying to figure out is what voltage that signal needs to be, how often it needs to be given, if it gets amplified or not in the cdi, and what the output signal should look like.
I have a variable dc power supply, and setting up a square wave should be easy enough using a relay.
Any suggestions/ideas/experience very welcome.
This post has been edited by jamesobrady: 20 October 2009 - 06:56 PM
