Has the present owner got the logbook when its time to do the deal,,if not i generally walk away from it,telling them when they locate it to give me a call back...
In the case of Northern Irish or U.K reg bikes their equivilant would be a V5 issued by the D.V.L.A...
If the owner gives you the registration number beforehand(presuming it's Irish registered) run a check on it on www.mywheels.ie...possibly sticked on the main page of the for sale page...there is a U.K equivilant if someone could stick up the details..
If the bike is Foreign registered including N.I and the U.K,try to find out the exact date of first registration and do a V.R.T (Vehicle Registration Tax)check to see what amount of duty is payable on it,all vehicles imported into Ireland have to pay V.R.T,think it's payable within 48 hours otherwise the bike can be impounded if stopped,this can be paid at your local V.R.T office,but beware they do not accept cash payment,laser or personal check..www.revenue.ie possibly stickied on the main page of the for sale page also..
Some of the checks on the bike that i look for...
Frame number/usually up at the heastock area around the main frame under the top yoke...make sure it has'nt been tampered with,1's made to look like 7's..6,s made to look like 8's etc...
Engine number/can be found usually lower down stamped into the main engine casings/some of the newer sports bikes GSXR'S etc can have the engine number stamped on the main engine cases just below the main swingarm pivot point,can be hard to find if your not sure where your looking..again make sure the numbers have'nt been tampered with..
Both of the above checks are pretty useless if the owner has'nt the logbook or V5 to hand as you've nothing to compare them against...
FRAME...
The main frame itself,,give it a good look over for any signs of hairline cracks,stressed areas,,check down on the bottom yoke if the lockstops on the yoke are bent or the main lock stop on the bottom of the frame headstock to make sure it isnt bent or marked up in any way,,the main frame itself,some aftermarket companies supply carbon frame covers as a nice bling bling touch but these can also cover up damage to the frame,,advisable to check underneath,if the seller is genuine and not hiding anything he should'nt mind removing them for a check...
FORKS...
i usually run my finger along them to see if there is any ripples in them,,can be a sign they were stressed with an accident..check the chrome on the fork sliders for wear,can be expensive to replace the sliders,,hold the front brake and pump the forks up and down a couple of times and check for oil on the fork legs to see if the seals need replacing..
BRAKES AND DISCS..
look at the discs front and back for signs of scoring,,where an owner may have let the pads wear down well beyond their limit,discs will need replacing,check thickness of the discs,,minimum disc thickness would be around 4mm..roll the bike forward and listen for any rubbing of the discs against the brake pads,,sign of a warped disc,,get down on the hands and knees and check the underside of the brake calipers to have a look at the brake pads and what life is left in them,should be an indicator line down the centre of the pad and it will show you how much life is left in the brake pads..
CHAIN AND SPROCKETS..
Have a look at the indicator marks etched into the swingarm where the rear wheel axle go's through and the plates that the axle passes through,both will give you an indication as to how much life is left in the chain,if its getting to to near it's furthestmost point on the swingarm the chain will need replacing soon,look at the teeth on the back sprocket to see their condition,how much wear on them,are they getting really pointy or starting to hook in one direction,believe me i have seen sprockets with teeth missing or that much wear that the chain is slipping off the teeth,,make sure the chain is tensioned when checking it,that the owner has'nt left it in approx the half way position on the swingarm markings with the chain loose to give the impression theres lots of life left in it,,when tightened the chain should'nt be solid that theres no movement in it,there should be approx an inch or so of up and down movement with the finger on it..
WHEELS AND TYRES..
check the edges of the wheel rims for scuffing/sure sign the bike has been slid down the road,,normal pinch marks happen with clumsy tyre changes,check the wheel paint to see have they been touched up hiding any visible damage,,if the bike has a centre stand,get it up on it and see if you can pull either wheel from side to side looking for movement which will result in the wheel bearings having to be replaced,,check the tyres for wear or see if their squared off,check the side walls of the tyres for any damage,,look for uneven wear of the the tyres,is the tyre wearing more on one side than the other,,could be out of balance,the owner may have preffered left to right hand corners or used a lot of roundabouts continueously taking 1st or 3rd exits
ENGINE....
i generally like to get the owner to start it up from cold/not always possible as most owners wont meet you at their house for security reasons/if meeting somewhere i usually take my time and look over the general condition of the bike first,talk a lot of sithe to while away the time and then check the oil level in the sight glass ask the owner to start it up,listening for any undue knocking/tapping/rattling noises/gremlins trying to make their way from the inside out..leave the bike run for a couple of minutes and all the time inspecting the engine for leaks of coolant in the case of watercooled or oil in oil cooled,,make sure to check the radiator and oil cooler for leaks,,have a look at the condition of the engine casings,are they scuffed or has the owner painted them up or polished them to try hide damage,any signs of gasket sealer around the edges of the casings where the casings had been removed previously and for what reason or why was'nt a genuine gasket used when replacing..check the exhaust while bike is running for any blowing and have a good look at it for rot particularly around the collector box under the engine..
FAIRINGS...
pretty obvious with stickers that may be hiding damage,cheap chinese aftermarket fairings that line up badly,grand for trackdays etc but overall quality of them is pretty poor in comparison to standard factory fairings,,look for scuff marks,badly painted panels,mismatching panels but not the obvious different colors,same colors but one panel faded more than others,,look at the bar weights for scuffing or replacements,same with levers,footpegs,mirrors,,look at the mileage on the bike,say a 3 year old bike with 20 to 35k on it,about average (with the exception of Ozzy
AFTERMARKET BITS...
race cans/if a carbed bike ask the owner was it jetted to suit the can/if fuel injected ask is there a power commander fitted,,ask are the standard parts available..if doing a deal on the bike also ask has the owner taken off any aftermarket parts,luggage rack etc,it may be a good time to strike up a deal if their wanted..
If going to buy it's a good idea to bring someone along with you who may not see the bike in the same light as yourself and offer critical advice or see bits that you may miss yourself...
There some of the main points,i know i have left some out as the eyes are getting tired and the fingers sore,,please feel free to add more checks to the list for prospective buyers as its all valuable info when going to hand over the cash...
If you do recieve a call from Renegades to have a look at the bike your selling do make sure its in good order or that the price reflects what needs to be done repair wise to put it in order otherwise i'll walk away laughing
This topic is locked
