Weird Tyre Wear
Posted 07 August 2010 - 02:18 PM
Run at 42psi ( as recommended)[attachment=19516:Reduced.jpg]
I know thats a good milage but has anyone ANY idea what is casing them to wear like this?
This is the second time out of four sets of tyres, the bikes were different.[attachment=19515:reducedTyre 2.jpg]
Posted 07 August 2010 - 02:27 PM
Posted 07 August 2010 - 02:30 PM
Posted 07 August 2010 - 02:32 PM
Posted 07 August 2010 - 03:06 PM
I would check that. 32 to 36 is more normal in the front. 42 is more common in the rear.
Posted 07 August 2010 - 03:31 PM
Posted 07 August 2010 - 04:23 PM
As regards the tyre wear, methinks you just need to change your tyres sooner than what your doing. There's no meat left on those tyres. That level of tyre wear is just dangerous.
Posted 07 August 2010 - 05:08 PM
Not having ago Kev
I can't believe that people let their tyres get this bad.
Some else posted up pictures wondering why their tyres were bald. I really do wonder sometimes
Posted 07 August 2010 - 06:23 PM
kido, on 07 August 2010 - 05:08 PM, said:
Not having ago Kev
It got a lot worse while I was away last week, the rear is fine and showing normal wear, the front has only just broken the min tread depth marker. figured it would last till I got back to Ireland and TBH, it didn't send me any warnings through the bars
Posted 07 August 2010 - 07:09 PM
Not having ago Kev
Tommy I have often ridden tyres down to the wire simply because I didn't have the money to replace them. But I do knwo where you are coming from in that I knew exactly the condition of the tyre.
And like Kev I was also caught short on a long trip.
Posted 07 August 2010 - 07:18 PM
Posted 07 August 2010 - 07:34 PM
Blackbird is similiar if you really let them go. As said, brave man letting them get that bad. Maybe try hard compound tyres perhaps.
Posted 07 August 2010 - 07:57 PM
I set up the bike with the back wheel set vertical with a spirit level. Often need to put a slip of something under one or other side of the centre stand depending on how level the ground is. Then use the steering to set the front wheel vertical too, Then check of the wheels are aligned. Your frame or forks could be slightly twisted. Even a small off can twist forks in the triple clamps.
Posted 07 August 2010 - 08:28 PM
relaxed, on 07 August 2010 - 07:57 PM, said:
Vertically aligned wheels!!!!????? thats something new. Tell me how to vertically adjust a wwheel??
#16
Posted 08 August 2010 - 12:39 AM
#17
Posted 08 August 2010 - 01:56 AM
#18
Posted 08 August 2010 - 06:41 AM
http://www.motorcycl...duct-Guide.aspx
http://www.dunlopmot...aq.asp?id=6#faq
http://www.rattlebar...lkfaq/tirewear/
This post has been edited by rubber56: 08 August 2010 - 06:41 AM
#19
Posted 08 August 2010 - 08:21 AM
ajoe90, on 07 August 2010 - 08:28 PM, said:
Easy. Set the back wheel vertical by adjusting the bike on the centre stand and a spirit level or plumb bob against the back tyre. Then turn the handlebars so the front is vertical too, again using the level. If everything is aligned properly the wheel alignment will be correct looking along the bike. A straight edge or tight string or laser line will show the same distance between the side of the narrower front and the rear on both sides.
If you have twisted forks, for example, you won't get the wheels aligned both vertically and horizontally. The rake of the steering head causes the front wheel to move off vertical as it deviates from straight ahead.
#20
Posted 08 August 2010 - 11:03 AM
Thanks Rubber56 - good links - looks like it's normal wear
