95 reg,
30k klms,
Was frontend damaged but frame is good.Ive replaced the forks,seals,mudgaurd,headlight and bracketing,axle and wheel bearings .Fitted renthals also as bars were bent.Mirrors replaced with a good set I had knocking about.
Pre crash I had done quite a bit of work for the previous 2 owners.Most recent work about 700 kms ago included O-ring chain and sprockets,rear Avon tyre,break pads all round,plugs,oil,filters and it had a new battery less than a year ago.Carbs were stripped and thoroughly cleaned and balanced also.
Bike has alarm,Givi Flyscreen, braided front lines and Hagon progressive springs also.
Bad points:Petrol tank has a few small dents(these are fairly un-noticeable),also it has one large dent about the size of a fist just above where the seat meets the tank,paint has broken so needs attention.Front discs are warped,an exhaust gasket is leaking also but I have a full set of replacements,and front tyre is shot.Shocks work but look scabby.Cheap prospect for someone or like I said I will break if enough interest.
Strong motor and good running gear.Pics to follow
This post has been edited by evoblade: 27 December 2011 - 11:46 PM
This topic is locked
